3D scanner
Anything related to 3D Printing...
uplus2user
3D scanner
Post by uplus2user » Mon Feb 23, 2015 11:58 pm
Hi, I am considering to buy a 3D scanner. One of the uses is to scan human body parts. Any good recommendation?
Numonic
Re: 3D scanner
Post by Numonic » Tue Feb 24, 2015 7:23 pm
Hi UpPlus User,
How much detail do you want on the humans? You can use a simpler and cheaper method using Xbox sensor, or go a little more and use use the 3D systems scanner. Personally I think there in the same category as the xbox scanner I've tried them both. Or you can use the Next Engine scanner this one is a bit pricer but yields far superior scans then the previously mentioned. You can also scan smaller objects as the first two do not do a great job at all.
If you have the funds your better off getting something more pro. Hope this helps.
http://cubify.com/en/Products/Sense
FallGuy
Re: 3D scanner
Post by FallGuy » Tue Feb 24, 2015 10:12 pm
Numonic is exactly right. The cost is going to come down to how precise (and how big) your scans will need to be. We use a Next Engine scanner in our office. It ran about $2600 when we got it and if I set it to do several scans and stitch them together, I get it to pick up resolutions around 0.001-in. in scans. In one initial trial scan, it was able to pick up the height difference of letters painted onto a coffee mug. But the actual useful scan volume for this unit is only about the size of a shoe box. You can scan some slightly larger objects, but at the cost of speed and resolution. We also went with the Rapidworks reverse engineering software which allows you to take the scan data, and convert it to a true Solidworks model that is fully editable. The rapidworks add-on was another $2500.
You say you want to scan body parts, you may be able to use a DIY type scanner based on the Xbox Kinect scanner. I use one of these at home for some of my own projects, and for larger items. I use the Skanect software to do it:
http://skanect.occipital.com/
But it looks like this has changed a bit since it first came out and I downloaded it. It looks like it will now only export models with a max poly count of 5000 with the free version. It use to be unlimited. But this still might be able to work for you even with that limitation. When I used this, if I took my time, it seemed like the minimum resolution was about 0.125-in. And there probably still are other open source freeware software options you could find that would use a Kinect sensor.
And just recently, I did go ahead and get in on a Kickstarter scanner project for home.
https://www.kickstarter.com/projects/15 ... ild-yourse
Looking at his resolution numbers and some of his sample scans, this should really do well enough for just small scan projects at home. For the cost, if I get consistent scans similar to what he got with his threaded bolt and nut example scan, then I would be happy. And obviously, being able to print parts for the scanner also appealed to me! If everything goes well, then I should get mine sometime in late April. Since it is open source, you might be able to modify something like this to suit your needs.
Good luck with your search.
Thanks,
FallGuy
uplus2user
Re: 3D scanner
Post by uplus2user » Thu Feb 26, 2015 12:26 am
Thanks. To provide more details... In one project, I want to get the curve-shape of the human body parts. It is a bit difficult for me to draw it in 3D software. In another project, I want to scan smaller objects perhaps also reflexive ones such as metallic objects. As you know, sometimes it is difficult to buy small parts. It may be more convenience to use 3D printer to reproduce the parts.
I plan to merge the scanned shape into another object in software (perhaps 3D CAD software such as SolidWorks?) Here is one sample application of the project: Scan the arm of somebody and use the scanned 3D model as the cast/body cover of a prosthetic arm.
Given the above, which product can do the job well?
uplus2user
Re: 3D scanner
Post by uplus2user » Thu Feb 26, 2015 5:48 am
Thanks. In one project, I want to scan a human curved body part (e.g. a leg) and use it as a body cover for a prosthetic leg. I think it is difficult to draw such curved surfaces in 3D software. So, one side of the 3D printed surface contains the scanned body part and the other side of the surface contains mounting holes to mount to the prosthetic leg. Any good way and equipment to do it? In another application, I want to scan small parts (including metallic parts if possible) and use 3D printer to reproduce the same parts or use 3D software to modify the parts and print them.
Numonic
3D scanner
Post by Numonic » Thu Feb 26, 2015 4:47 pm
upplus2user,
My money would be on the NextEngine Scanner, I would also use Rhino and T-Splines to get those nice soft curvy features. But you're going to keep busy doing all those things mentioned in this project. There will be alot of trial and error but keep and it and you'll finish the project. If you can post some pictures up of your progress it's an interesting project and 3D printing lends itself to this sort of thing greatly!
Best
uplus2user
Re: 3D scanner
Post by uplus2user » Thu Feb 26, 2015 11:56 pm
Numonic wrote:upplus2user,
Best
Numonic, giving the time I am going to spend on trial and error, is it better to create the 3D surfaces on 3D software using the mouse or pen tablet?
Numonic
3D scanner
Post by Numonic » Fri Feb 27, 2015 3:10 pm
It all depends on what style you like to work on and your preference. For sculpting software it would be better to work with the pen. But for software like T-Splines I've never used a pen and tablet I use the mouse. When I use Zbrush or Mudbox I use the pen, but if you are fortunate to own a Phantom Pen with Freeform software you'll be able to feel the clay and resistance on each area. That is a really great way to model and feel out the contours of your 3D model. To to take as much measurements in real life as possible as that will help you greatly on your pursuit for getting all those parts to fit.
Even with all that and we can't forsee every detail and we are all bound to mistakes heck this is prototyping, this is the time to screw up and figure it out and then produce
a clean and refined product once all that is said and done. Remember have fun in the process that's why we all do this stuff :D .
Looking forward to the results keep me posted.
Best
Numonic
car3less
Re: 3D scanner
Post by car3less » Wed Apr 20, 2016 11:02 am
Did anyone use Structure Sensor from Occipital?
Tiger
Re: 3D scanner
Post by Tiger » Thu Dec 01, 2016 1:53 pm
No, but i tried kinect V2 and Intel RealSence, woth artec studio. Not sure it can be used with occipital's sensor, you may ask there https://www.artec3d.com/support
smith59
Re: 3D scanner
Post by smith59 » Sat Jul 08, 2017 12:56 am
Numonic, giving the time I am going to spend on trial and error, is it better to create the 3D surfaces on 3D software using the mouse or pen tablet??
Eloy
Re: 3D scanner
Post by Eloy » Tue Sep 26, 2017 6:36 am
If you want to purchase 3D printers, you may visit http://3dinsider.com/3d-printers-for-sale/. Here you can find all best model at affordable price.
seorm10
Re: 3D scanner
Post by seorm10 » Tue Dec 26, 2017 12:00 pm
I totally agree with this point.
steve3dprinters
Re: 3D scanner
Post by steve3dprinters » Wed Aug 08, 2018 6:35 am
You can get an Cowtech "Ready to Scan" Ciclop 3D Scanner Kit from 3D Printers Bay and use it for any kind of 3D scanning job you come across.
patil321
Re: 3D scanner
Post by patil321 » Fri Feb 22, 2019 4:39 am
Great information
ellajonshon87
Re: 3D scanner
Post by ellajonshon87 » Mon Apr 22, 2019 6:44 am
Recently I bought a 3D printer but when I tried to use my 3D scanner it shows an error dell error code 2000-0333, I really have no idea how to remove thios error so I want a solution how to remove this error as soon as possible.
Owen Sparks aka Marksman
Re: 3D scanner
Post by Owen Sparks aka Marksman » Tue Apr 23, 2019 11:43 am
Spam alert.
