resin vs filament?
mec949
resin vs filament?
Post by mec949 » Sat Nov 22, 2014 4:42 am
I havean up plus 2, which I am vrry happy with.
But I have seen resin printers becoming cheaper with excellent resolution.
Examples being the ibox nano (I know tiny build area) note if the small one is sucessful a bigger one will be released.
What are your thoughts and experiences?
wilsonj
Re: resin vs filament?
Post by wilsonj » Sat Nov 22, 2014 9:59 pm
SLA gives better quality and resolution, but it is generally smelly, sticky, messy and more expensive.
Parts from SLA machines can also be much stronger, but also brittle and sensitive to sunlight which increases this issue over time.
I've had a Form1 and Form1+ as well as have a MakeX on the way. So far not impressed. My FDM printers keep working away, while I mess around and spend painfully large amounts of money getting the Form1 to work. Which it currently doesn't.
Bottom line for me, if the SLA printer worked successfully as often as the FDM then there would be no question which I prefer. But that just isn't the case, at least in my experience.
mec949
Post by mec949 » Sun Nov 23, 2014 2:36 am
wilsonj wrote:SLA gives better quality and resolution, but it is generally smelly, sticky, messy and more expensive.
Wow that is surprising considering the reputation they have.
I have been looking for a decent resin printer just so I dont have to be limited by the f* support material, which, lets face it is a pain.
Have you looked at the ibox nano for small stuff? Apparently, if it is successful they will release a bigger one half way through the year
Post by DrewPetitclerc » Sun Nov 23, 2014 5:07 am
mec949 wrote:
wilsonj wrote:I have been looking for a decent resin printer just so I dont have to be limited by the f* support material, which, lets face it is a pain.
You do realize that the "resin" printers still have support material you will have to remove, just think about how the parts are printed and you will come to realize that the only printers currently that can print without any support are the "powder" based printers as the excess powder acts as the support.
Drew
Post by roller » Sun Nov 23, 2014 5:56 am
Which is why my drew is a cheap reliable powder printer.
mec949
Post by mec949 » Sun Nov 23, 2014 9:01 am
Drew
Of cause I know they still need supports.
I am under the impression that they may need less support than filament printers.
roller wrote:Which is why my drew is a cheap reliable powder printer.
what sort of printer is this ? havnt heard of A "drew" or have I misread your post
wilsonj
Post by wilsonj » Sun Nov 23, 2014 6:33 pm
Actually I find the Form1 uses just as much, if not more support than FDM, and is often much harder to remove and requires sanding the area afterwards.
As Drew mentioned, only SLS powder based systems will offer true support free printing.
No haven't tried the ibox nano, but as it works in basically the same way it will have all the same issues.
teamcarlisle
Post by teamcarlisle » Sun Nov 23, 2014 9:26 pm
I was also under the impression that the Form1 uses just as much if not more support. Apparently with the Form1 and, I would assume, other resin printers in general they usually place objects at an angle on the print bed, instead of flat. I believe is has to do with the peeling process, and forces bring exerted. I've seen a lot of photos of resin prints that could have been done on an FDM printer without support, but on the resin printer they had to use support. With resin being a lot more expensive than filament, that makes for some very expensive support material by comparison.
http://formlabs.com/en/support/help/bas ... our-print/
http://formlabs.com/en/support/help/adv ... pports-do/
Post by roller » Sun Nov 30, 2014 9:06 am
Oh dear ... some horrible autocorrect there. I meant, "Which is why my desire is a cheap reliable powder printer."
Post by DrewPetitclerc » Mon Dec 01, 2014 2:08 am
I just thought you where thinking about me when you where typing and felt myself blush. :oops:
:lol:
Drew
caesar
Post by caesar » Tue Dec 02, 2014 9:51 am
Still, have to admit that it came out perfectly. Maybe that autocorrect was on to something ;)
You made my day!
Cheers
brainzilla
Post by brainzilla » Wed Dec 03, 2014 1:19 am
Yeah SLS is the way to go...
But then you have all that nasty dust at home. Not really a thing I want want to mess with.
I have some Nylon SLS prints from shapeways, they are plain awesome. And pretty much indestructable.
As long as the price for those goes down I am happy to order them online or maybe soon somewhere local.
As far as color printing goes, I would love to see a MCOR paper printer live...
Post by roller » Wed Dec 03, 2014 12:45 pm
MCOR was ok ... I wasn't that impressed. I am not too worried about the dust from the powder printer as the CNC far outdoes it for mess.
