UP! ABS filament in Multiple colors
Anything you like to buy, sell, offer, or hire from the fellow Uppers?
jmorro
Post by jmorro » Wed Oct 24, 2012 12:02 am
I just noticed that USBcopiers.com has the real UP! filament in multiple colors. They are sold in 2 spool bundles at a decent price. they also have a six spool bundle with one of each color. You can see them at the bottom of this page, http://www.usbcopiers.com/abs-1-75mm-filament.html
Might be worth a try. I just placed my order for the green. I will let everyone know how I like it.
UPUPandAway
Re: UP! ABS filament in Multiple colors
Post by UPUPandAway » Fri Oct 26, 2012 9:59 pm
Octave.com also stocks official filament for roughly the same price, though they may brand it "Afinia", which is exactly the same thing as the UP! with rebranding of questionable necessity.
nuproto
Post by nuproto » Mon Dec 10, 2012 7:19 am
UPUPandAway wrote:Octave.com also stocks official filament for roughly the same price, though they may brand it "Afinia", which is exactly the same thing as the UP! with rebranding of questionable necessity.
does this one work with up mini?
http://www.octave.com/p1173433108/Octav ... _info.html
LonV
Post by LonV » Tue Dec 11, 2012 4:12 am
Yep, the non-Afinia stuff from Octave works great. It's worth noting that it does melt at a lower temp than the Up!/Afinia (to be compatible with other printers), but it's what I've been using exclusively since I got my printer.
ahd71
Post by ahd71 » Tue Dec 11, 2012 8:16 am
I haven't tried that one yet but in case it melts at a slightly lower temperature the mod I made (http://www.pp3dp.com/forum/viewtopic.php?f=28&t=2527) will most likely resolve the issue.....
LonV
Post by LonV » Tue Dec 11, 2012 5:21 pm
FYI, Octave has just started selling a temperature switch (similar to other things mentioned in other threads). This should work with any aftermarket ABS that melts at a lower temperature. I ordered mine today, I'll let you know how it works.
http://www.octave.com/p1173433163/Extru ... _info.html
christianz
Post by christianz » Thu Dec 27, 2012 4:57 am
Thanks "LonV" i go to your provided URL and get my point thanks again..
pzac
Post by pzac » Tue Jan 01, 2013 9:29 pm
I have installed the temperature switch from Octave.com ($20.00 USD) and it works great.
It is easy and inexpensive solution (it take just a couple of minutes to install) to lower the temperature on your Up you might want to consider the Octave solution.
Here is a link to the switch on Octave: http://www.octave.com/p1173433163/Extru ... _info.html
and a YouTube video show how to install it here: http://www.youtube.com/watch?v=kUplLBla-0o
I use the Octave ABS along with their switch and the prints come out great.
However the raft and supports are sometimes more difficult to remove on some models.
josejuako
Post by josejuako » Thu Jan 03, 2013 2:02 am
josejuako wrote:Here are all info
http://www.3ders.org/pricecompare/
Filaments Suppliers and Machines
