The UP is an awesome 3D Printer!
Post by wackojacko » Mon Mar 05, 2012 1:52 am
Thanks to Olaf for the STL file, I didn't think it would print in one go, but it did! :D
http://www.youtube.com/watch?v=6o1chNIFOXo
Marcus
Re: The UP is an awesome 3D Printer!
Post by Marcus » Mon Mar 05, 2012 3:35 am
That's a beautiful print! It could make a nice bracelet :-)
The UP's amazing, I bet you could print that at half scale without much problems.
Even this http://www.thingiverse.com/thing:14363 worked ^_^
odiegel
Post by odiegel » Mon Mar 05, 2012 4:19 am
Nice job!
Amazed you didnt slash your hand a few times when removing the support material... :-)
Cheers
Olaf
Madox
Post by Madox » Mon Mar 05, 2012 4:43 pm
odiegel wrote:Nice job!
Cheers
Olaf
We need a separate gallery on showing wounds...
Marcus
Post by Marcus » Mon Mar 05, 2012 6:04 pm
Or a band-aid printer.
FallGuy
Post by FallGuy » Mon Mar 05, 2012 6:25 pm
I could barely watch the video seeing the gloveless hands! I really did almost take a thumb tip off with a wood chisel while removing support material. My fault completely, early morning, just a small part, not much to remove, so no need for gloves, and a quick slip and it was over. After a month, feeling started to return, but in the cold snow now it aches a little bit. Picked up a set of cut resistant gloves and I won't even pick up my tweezers without putting them on! For all new users, be careful, even some edges of the raft ABS pieces can be extremely sharp and can do damage. Take your time and wear the gloves and eye protection! I bet there have been more serious incidents than what we have heard of. Sorry to get off on a tangent there.
I do have to say the model was fantastic!
Thanks,
FallGuy
Marcus
Post by Marcus » Mon Mar 05, 2012 6:59 pm
True. I only had few minor accidents but finally ordered safety gear.
It's rather inexpensive, too;
Glove Search
Safety glasses
Perhaps PP3DP should add glasses to the set? :-)
pleppik
Post by pleppik » Tue Mar 06, 2012 4:24 am
wackojacko wrote:Thanks to Olaf for the STL file, I didn't think it would print in one go, but it did! :D
Okay, I'll bite....Is it posted to Thingiverse?
Post by wackojacko » Tue Mar 06, 2012 4:36 am
It is available on Olafs site www.odd.org.nz
odiegel
Post by odiegel » Tue Mar 06, 2012 5:06 am
And check out my awsome 3d printed guitars while you are there... :-)
Cheers
Olaf
odiegel
Post by odiegel » Tue Mar 06, 2012 5:08 am
Forgot to add... Ring on my site is finger sized. Just scale it up to around 100mm diamter and it will print fine.
Cheers
Olaf
pleppik
Post by pleppik » Wed Mar 07, 2012 11:54 pm
Printed one last night. It turned out beautifully.
odiegel
Post by odiegel » Thu Mar 08, 2012 5:04 am
When I did one, I did it at 0.3mm resolution (I use this for most prints), normal speed, and it took about 4 hours to print.
Olaf
josejuako
Post by josejuako » Sun Mar 11, 2012 3:45 pm
Odiegel I like to know as it broke or not print whit this tooth , whit your UP PLus ?.
odiegel
Post by odiegel » Sun Mar 11, 2012 7:32 pm
The one I printed had no broken teeth at all. But, obviously, I was fairly careful in removing the support material. I do have the fan mounting mod, that blows air onto the print area, installed on my machine, whcih does meake the support material enormously easier to get off.
Will post pictures of mine when I get home tonight.
Cheers
Olaf
josejuako
Post by josejuako » Sun Mar 11, 2012 7:48 pm
Odiegel thanks a lot to day i understand the use for the air is good to us this Drew contribution , here are a good team.
Thanks for you replay , I'll see you.
Best video I forget to say.
Jose
delleps
Post by delleps » Sun Dec 23, 2012 1:14 am
Is there any way to get the .STL file from anyone who has this? I have looked on the website given but the page and file appears to have been removed. thanks!
delleps
delleps@hotmail.com
