Thank you PP3DP for such a high detail device.
Marcus
Post by Marcus » Wed Feb 29, 2012 10:25 pm
Thank you PP3DP for such an amazing machine!
Turning gramophone http://www.thingiverse.com/thing:17822
Gramophone
Working woolwinder http://www.thingiverse.com/thing:18286
Working Woolwinder
Working Padöck http://www.thingiverse.com/thing:17973
Working Padlock
The lock worked on the first try. This device really turns ideas into reality.
I just wish it would be possible to print <0.2mm layers or a detail-mode that slows down even more. If one of the future updates will somehow take care of the gaps ( http://pp3dp.com/forum/viewtopic.php?p=5713#p5713 ) It would be great, but not sure if it is even possible without smudging it.
Marcus
Re: Thank you PP3DP for such a high detail device.
Post by Marcus » Fri Mar 02, 2012 1:53 am
http://www.thingiverse.com/thing:18414
http://youtu.be/4IW8tY8FLsU
It really "works" :-)
Sorry for the bad pictures/videos, darn batteries...
Post by wackojacko » Sun Mar 04, 2012 9:04 am
That's insanely small, how long does it take you to assemble the typewriter
Marcus
Post by Marcus » Sun Mar 04, 2012 11:44 am
Strangely the typewriter was very easy to clean and assemble (and quickly printed, too)!
The wool winder for example has fewer mechanics and was tedious to assemble and glue (had to let things dry, fixate, hold...)
Basically you take one "slice", put the two wheels/gears on the axis, then the type hammer and the key.
Only the long type hammer tends to fall out, but as soon as you place the next slice/layer ontop, it will stay in place.
After you prepared your typewriter sandwich, add a few drops of instant glue to the edges, press down for a minute, and it's ready to use.
I thought of adding a base to press-fit (similar to the wool winder's lid) but it works good as it is and does not require so much accuracy as long as the roll stays in place it's all good.
