MY FIRST MODEL - WILL NOT PRINT
andyanthony
Post by andyanthony » Fri Mar 24, 2017 7:39 pm
I've had a few other people look at it who don't use UPStudio and it renders fine for them.
I designed a Nintendo Switch Joy-Con SuperMini Grip. But I'm unable to print this out. My printer is an UP BOX+ which uses their own software, but I haven't had issues like this before. It literally prints a line over and over on top until I stop it after the 10th pass. I've done everything I can. I've even run a repair in meshlab, mesh mixer, and netfabb online.
https://file.town/download/xw38ji34lre70mgzf1j3tctz2
pleppik
Re: MY FIRST MODEL - WILL NOT PRINT
Post by pleppik » Fri Mar 31, 2017 8:07 pm
Can you print other models OK?
My first guess would be that one of the axis steppers isn't working. You should rule that out before assuming it's the model.
ricks01
Post by ricks01 » Fri Mar 31, 2017 10:11 pm
upload the .stl file to thingiverse.com, if you want to keep it private don't publish it, just click "save and view" when done uploading and private message me the url.
