Helmet clip for GoPro
Chris botha
Post by Chris botha » Sat May 10, 2014 12:21 pm
Billzilla
Re: Helmet clip for GoPro
Post by Billzilla » Sat May 10, 2014 9:24 pm
Very neat.
Chris botha
Post by Chris botha » Sun May 11, 2014 9:12 am
ming
Post by ming » Sun May 11, 2014 12:29 pm
Very nice
Looks like a commercial product
Dream@night / Holdit@sameday
Chris botha
Post by Chris botha » Tue May 27, 2014 1:54 am
Phase 2... fitting an inside helmet mic with clipons on the clip.. pity about the colour that happened to be on the printer at the time...
Will post images of finished goods when its done, but i reckon you get the idea..
Chris botha
Post by Chris botha » Tue May 27, 2014 9:55 am
and finito.. this filament was AWFULL.. i had to carfully get the supports off then basically baste it in acetone to get it NOT to peel apart.. zero cohesion.. and its YELLOW!!!!!
If i did the mathematicalisms corectly it should give me eyeline centred view as well
http://www.youtube.com/watch?v=WjYyqvJFMnQ
[edit] my math kungfu was good!
http://www.youtube.com/watch?v=erdm56bci5w
Chris botha
Post by Chris botha » Tue Jun 03, 2014 10:47 pm
I went down to the local JayCar and bought this mic, splitter, some cable and some jacks.. and hopefully what we will see by end of project is dual feed to GP2, for a whopping $16.. in helmet and from back of bike.
on back of bike I am not sure yet, if underseat, or on the top of seat. either way i need to limit the wind noise so built a housing on the printer to fit the mic and close of its side holes, so its directional only, using the mics own rubber backing to seal the rear entry.
this will be attached with a square of mirror mounting double sided tape (cuz thast what i have laying around) under the seat cavity in test 1, and then im going to print tonight a "buckle" that will fit on the strap on the back of the MT seat to slide the housing into so i can record on TOP of the seat, facing backward..
Will test both this weekend and update this same post.
Post by DrewPetitclerc » Wed Jun 04, 2014 12:26 am
Nice design!
Please don't be like the organ donors I see on youtube splitting lanes at high speed, running up my motorcycle insurance premiums. :lol:
Drew
Chris botha
Post by Chris botha » Wed Jun 04, 2014 3:00 am
Ha! One always hopes not.. and yet here i sit with a reconstructed shoulder, 3 disc operations and a smashed up knee.. not bad for 25 years of biking though all up.
I see i missed a post as part of this project in here somehow.. i made a Hook/Sheild on for my intermnal mic too so you can hear my melodious voice and engaging commentary as I ride..... :roll:
Mic shield build
http://www.youtube.com/watch?v=lETXzEpBQ4Y
and the feed at 60 - 1??km/h
http://www.youtube.com/watch?v=YA-Fu8BYJYg
after my "engaging commentary most folks felt it was probably best if i setup a rear mic to get the MT's booming exhaust sound instead :lol: :lol: :lol: :lol: :lol:
Chris botha
Post by Chris botha » Wed Jun 04, 2014 11:37 am
When engineers make a mistake , they dont call it a mistake.. they call it a development prototype..
the first version of the clip was no good, my strap was way too tight.. and the cohesion in this printed material, way to low.. SNAP!
revised that sucker to this more robust version! and printing lengthways so "grain" is along the tension not across it...
"we learn the limitations and the strengths of the tool, and develop for its strengths, rather than its weaknesses"
Chris botha
Post by Chris botha » Wed Jun 04, 2014 10:23 pm
and done! tested the fit on bike seat, fits great!
https://www.youtube.com/watch?v=twH7rDmvYt8
ming
Post by ming » Wed Jun 04, 2014 10:35 pm
Glad to see you are utilizing your creativity and the printer to make functional items.
The reason i got the 3d printer is that i can make many many many mistakes early and fast - ooops
Because if i make an OOPS it may be very costly down stream and some times very bad outcomes.
OOOPS = development prototype :)
Chris botha
Post by Chris botha » Wed Jun 04, 2014 11:00 pm
oh.. PS.. if anyone is wondering how my printer is suddenly printing ok even with the winbo filament.. a spanner, a hammer and some swearing fixed it.. I will try get time on weekend to photograph the part of the printer that was causing the issue and how to fix it. its a very fundamental design flaw in this printer and what happened to mine can happen to anyones..
the clip above printed in winbo filament at full temp, no mods. supports broke away easily, part surface is great etc.. more what I was expecting..
[edit] info on fix here http://www.pp3dp.com/forum/viewtopic.ph ... =40#p40803
