Blossoming lamp by Emmett
pp3dp.nl
Post by pp3dp.nl » Sat Jan 05, 2013 10:23 pm
Most of you know some things designed by Emmett I think. I had to try the blossoming lamp and it came out great! On the Up Plus I had to scale it down to 87%, I used 0.20 mm layers and white ABS. I couldn't find thin enough LED lights so I tried 7 Watt switch board light bulbs and an E14 fitting. Luckily it doesn't get too hot to melt anything and 7 W is bright enough.
The files can be found here: http://www.thingiverse.com/thing:37926
Everybody should try to print this :D
Blossoming Lamp.jpg (243.79 KiB) Viewed 5735 times
Re: Blossoming lamp by Emmett
Post by wackojacko » Sat Jan 05, 2013 11:20 pm
Wow, that is an amazing print. Now just to have a light sensor and motor, so it opens and switches on when dark.
pp3dp.nl
Post by pp3dp.nl » Sat Jan 05, 2013 11:35 pm
Somebody made that already:
http://www.youtube.com/watch?v=Or4bN1Sv ... e=youtu.be
But I'm not and Arduino specialist, that's why I'm an Up! fan ;)
pp3dp.nl
Post by pp3dp.nl » Sun Jan 06, 2013 7:37 pm
And I tried one in green:
nancynany88
Post by nancynany88 » Wed Mar 13, 2013 5:51 am
hmm what an idea it is. i have also creat such a blossoming lamp its trully awesome. :geek:
