Combination Lock
cyberbadger
Combination Lock
Post by cyberbadger » Fri Jan 07, 2011 4:25 am
Great Print from thingverse!
I had to scale the STLs in the UP software by a factor of 30. - ended up being exactly or almost exactly the size that the designer printed on a Stratasys - about 4" or so in the longest dimension. See the US quarters in the pictures for size reference. Quality I think is very comparable.
Printed great. It's a functional model of a combination lock that you can observe the mechanism.
I used a little epoxy to permanently assemble it. I used a black sharpie to give the dial highlights.
http://www.thingiverse.com/thing:2047
-cyberbadger
Marcus
Re: Combination Lock
Post by Marcus » Fri Jan 07, 2011 9:21 am
Awesome! I should definatly print this once I get my printer :-) Hopefully I can get it to print as nice as yours...
TeamTeamUSA
Post by TeamTeamUSA » Fri Jan 07, 2011 9:50 am
Great print! :)
What settings did you use?
This is one of those "WOW!!" prints that are great at demos; definitely going to print one!
Go!
=ml=
¡Fabricado no TeamTeamUSA!
Gilius
Post by Gilius » Fri Jan 07, 2011 4:27 pm
I second the settings question.
Just upscale all the parts 30 times?
cyberbadger
Post by cyberbadger » Fri Jan 07, 2011 10:22 pm
Settings:
0.2mm
Normal
The Fiber glass Prefboard on the platform
vibez
Post by vibez » Fri Feb 25, 2011 9:33 pm
WOW this looks awesome. Did you print it all in the same orientation as on thingiverse? The base looks like it will need a fair few supports
josejuako
Post by josejuako » Sat Feb 26, 2011 2:32 am
Excellent congratulations .
J
daem0n2
Post by daem0n2 » Sat Feb 26, 2011 5:20 am
Wow one of the best models that I've seen on any system. Can you provide us with more details on how you created the model in software?
Madox
Post by Madox » Sat Feb 26, 2011 3:35 pm
daem0n2 wrote:Wow one of the best models that I've seen on any system. Can you provide us with more details on how you created the model in software?
He printed someone else's model, it was done in Solidworks if I remember, it is described in the Thingiverse link.
Marcus
Post by Marcus » Tue Mar 22, 2011 9:26 pm
Not quite as smart, but a fun little lock: http://www.thingiverse.com/thing:7255
A rough work-in-progress, but I really had fun making this one.
-soapy-
Post by -soapy- » Tue Jun 28, 2011 1:49 pm
I'm printing this now, I've done the base part, and two of the wheels are printing right now. I'm doing them at 0.25 res, with minimal support, and the biggest part has come out fine, just a little filing and support removal to give a great part.
You have to scale it up into inches, though (x25.4) as the units are set wrongly.
