Reims Cathederal kitset
Share projects and models that you like, and wow the fellow Uppers!
m_bergman
Post by m_bergman » Tue Nov 20, 2012 10:00 am
62 pieces. Assembled weight 270g.
Drawn in Solidworks, printed on UP Plus.
Lawrence
Re: Reims Cathederal kitset
Post by Lawrence » Tue Nov 20, 2012 10:06 am
Absolutely fantastic. I am in awe!
pp3dp.nl
Post by pp3dp.nl » Tue Nov 20, 2012 10:19 am
Wow... That is just insane! Looks really good.
woofy
Post by woofy » Tue Nov 20, 2012 10:34 am
Absolutely the best printed model I've ever seen.
Tick VG.
amd-tec
Post by amd-tec » Tue Nov 20, 2012 11:35 am
Nice , really nice!
http://www.amd-tec.com
Post by roller » Tue Nov 20, 2012 11:48 am
<stands to applaud> As someone who does a lot of architectural models and has been to the original ... that is absolutely spectacular!
Macman
Post by Macman » Tue Nov 20, 2012 12:17 pm
Wow, how long did it take to design print and assemble ? What an amazing advert for the UP plus...
Do you have any pictures of the components being printed.
Macman :shock:
Post by wackojacko » Tue Nov 20, 2012 5:57 pm
That is an incredible print and the detail is incredible, absolutely fantastic!
amd-tec
Post by amd-tec » Tue Nov 20, 2012 7:10 pm
This model and these pictures are the best value for pp3dp and for UP 3d printer marketing sofar!
m_bergman
Post by m_bergman » Wed Nov 21, 2012 7:54 am
I will release the .stls this weekend after I have made an assembly instruction sheet.
Some of the parts can be a bit challenging to make, and the assembly is not for novices.
Blown454
Post by Blown454 » Wed Nov 21, 2012 8:08 am
Wow! That is just amazing!! Can't wait to see the files to give it a go... ;). Thanks for sharing such awesome work!
teamcarlisle
Post by teamcarlisle » Wed Nov 21, 2012 9:04 am
Awesome print!! Just out of curiosity, what kind of paint have you found best for abs. I havent painted anything yet, But getting to the point I might start
APA
Post by APA » Wed Nov 21, 2012 2:58 pm
Amazing job; both on the SW models and the prints! That is a ton of work and the result is well worth it.
Thanks for sharing!
Marcus
Post by Marcus » Wed Nov 21, 2012 3:38 pm
Wow! Amazing!
Post by wilsonj » Wed Nov 21, 2012 7:39 pm
Truly awesome!!
What filaments were used ?
FallGuy
Post by FallGuy » Wed Nov 21, 2012 8:35 pm
That is an amazing job! I would be interested in some of the details of HOW you did it. You say you modeled in Solidworks, did you import any form of scan data, or did you model from scratch?
And the finish detailing is stunning. I think we would all be thankful for details on how you achieved it, from initial surface prep, to the type of paint used.
That is definitely an achievement and something to be proud of!
Thanks,
FallGuy
m_bergman
Post by m_bergman » Wed Nov 21, 2012 9:58 pm
FallGuy wrote:I would be interested in some of the details of HOW you did it. You say you modeled in Solidworks, did you import any form of scan data, or did you model from scratch?
pp3dp white filament.
0.2mm, normal, loose, 3mm raft.
Perfboard (screwed to plate) with thin smear of liquid ABS before each print.
All parts drawn from scratch, referencing L'instant Durable paper model, internet photos and books.
Parts assembled with acetone, wicked between parts with a syringe. Hold together / clamp until dry (about 5 minutes.) All fine details had a wicking of acetone to strengthen them. Blow on the surface of the part after applying acetone to ensure there are no pools or puddles and the excess is spread out and can evaporate. If you leave a puddle the ABS goes gooey and can take a day or more to cure.
Surface prep - remove strings, raft. That's it.
Paint job is quick and nasty, mainly to highlight the details.
Painted using mostly Citadel Acrylics (Acrylics best choise for ABS. I like the Citadel ones for brushwork, as they are thicker, especially the new formulation base colours which cover really well with one coat.)
Base coat Citadel Desert Yellow, thinned, paint both sides ( or else the white makes it look translucent.)
Roof Airfix acrylic #56 (from memory), not thinned.
Quick wash of Citadel Flesh Wash, varying levels of thinning, around all the statues, details and roof tops.
Citadel Black Wash for darker details.
Drybrush of Citadel Codex Grey in places where the wash had covered too much of the base coat.
Post by JuliaDee » Thu Nov 22, 2012 4:59 am
It seems superfluous after all the other comments, but I have to add my own WOW to the thread. Mr. Bergman, you rock.
