Hi.
The model came from The Art Institute of Chicago.
It is possible to get the STL Files that scaned by 123D Catch in the art museum.
http://blog.123dapp.com/2012/09/the-art ... rtual-tour
The Solitude of the Soul.
Re: The Solitude of the Soul.
What filament did you use? Any post-finishing, like painting? Really looks like stone or at least plaster!
I used normal gray ABS filament.
And there was no post-finishing at all.
There's only difference of working temperature.
I have made two of statue.
The left one is in case of low temp.(200~210deg, I don't know the exact temp.)
The right one is in case of high temp.(240~250deg)
In case of low temp., It shows more mat surface than the high temp. conditon.
So it looks like a stone or plaster as you felt.
At the high working temp, the surface looks more glosy.
