Cable Carrier!
jspark
Cable Carrier!
Post by jspark » Mon Sep 03, 2012 8:54 am
Hi!
I tried to make a Cable carrier.
The Industrial name is "Cable Veyor"
It helps to prvent folding of electric wires in the moving environment.
The model's width : 24 mm, hieght : 10 mm.
I found that there are only 4-layers per 1mm on the 0.2mm z-resolution.
Is that Right?
I think it must be 5-layers per 1mm in case of 0.2mm z-resolution setting.
Anyway the result was very cool!
Cable Veyor Printing Test by J.S.Park
eyUP
Re: Cable Carrier!
Post by eyUP » Mon Sep 03, 2012 2:01 pm
That has come out really well!
I've always called them drag chains btw
wilsonj
Re: Cable Carrier!
Post by wilsonj » Mon Sep 03, 2012 3:12 pm
Very cool.
