calibration
Posted: Fri Jan 13, 2012 4:29 pm
by tshe1
i have my UP1 printer for two weeks and wanted to check the calibration.
first i printed the calibration model and find X1=126.2 X2=124.2 H=40.45 Z=-0.25.
i measured the distance while the parts were hot (after cooling down it shrenked a little bit), is it OK?
anyway, i added the values to the dialog box.
i wanted to check againg the calibration (improvement) and i didn't want to go thrugh over 1 hr waiting so i designed my own lightwaigh calibration model
(in SOLIDWORKS) which has diagonal distance of 124.0mm between the parts, and one L hape in the front center.
the results were: X1=124.7 X2=124.65 H=40.1 Z=-0.1
if i reset the dialog box and add the values, is the softwere will compensate according to previous values or according the printers original?
do you get accurate results after printing?
thanks a lot,
Tsvi
my lightweight calibration model
Re: calibration
Posted: Fri Nov 09, 2012 12:53 am
by nuproto
where can i get this model.. thanks
Re: calibration
Posted: Fri Nov 09, 2012 2:54 am
by doraemon
The parts should be in your UP install folder on your computer, under the Example subfolder. Part is called Calibrate96.UP3, or at least that's what on my system.
Re: calibration
Posted: Fri Nov 09, 2012 11:12 am
by eyUP
if i reset the dialog box and add the values, is the software will compensate according to previous values or according the printers original?
IIRC adding new values will ADD them to the previous values. You have to hit RESET to clear the previous values (even though they don't show in the dialog the next time it appears they are still active)
Re: calibration
Posted: Mon Nov 04, 2013 2:07 pm
by syncra
Please I am desperately looking for the calibration file that I lost - anybody can send a link on where to download it?
Or pm me directly...
Re: calibration
Posted: Mon Nov 04, 2013 5:02 pm
by mb20music
syncra wrote:Please I am desperately looking for the calibration file that I lost - anybody can send a link on where to download it?
PM sent
Re: calibration
Posted: Mon Nov 04, 2013 5:55 pm
by wackojacko
If you install the Windows software then you will find it in program files/up
Re: calibration
Posted: Mon Feb 17, 2014 1:42 am
by Tiertime-Roman
You can dowload the latest software from the homepage, and the files have been in the installed folder.
Re: calibration
Posted: Sun Nov 27, 2016 6:52 pm
by espinetegg
hi, one question
is possible to calibrate with up studio software? how?
thanks
Re: calibration
Posted: Mon Nov 28, 2016 3:21 am
by Tiertime-Jason
The calibrate function will be added in later version, so now is not possible.
Re: calibration
Posted: Tue Dec 06, 2016 6:04 pm
by NightShiftNeverEnds
and where can I find the files on my OS X/mac?
So long,
Michael
