Question about Up! Plus hole capabilities
hajime
Post by hajime » Tue Apr 30, 2013 3:22 am
Hi, considering to buy the UP! Plus. I want to use it to make some frames with holes for the metal screws. How small can the holes be while they are still circular? On the MakerBot Replicator 2, even hole for M2 screw cannot be circular. Can somebody post a photo of holes of various sizes, say at M1.5, M2, M2.5? Thickness of the frames can be 1.5 or 2mm.
Lawrence
Re: Question about Up! Plus hole capabilities
Post by Lawrence » Tue Apr 30, 2013 6:15 am
Hi
I had this model on hand with 2.81mm diameter holes - three each side of the small enclosure. I also made the nuts and bolts that secure the lid on it.
Showing the accuracy of the Up!Plus, I also made the M2.8 nuts and bolts that were used to secure the lid.
If that does not convince you of the accuracy of the Up!Plus then I doubt that anything will convince you.
Lawrence
Post by wackojacko » Tue Apr 30, 2013 6:43 am
Hi Lawrence
Great example, any chance we could show your model at Austech next week in Melbourne. Any one in Melbourne swing round and say hello, it's free to register.
Lawrence
Post by Lawrence » Tue Apr 30, 2013 11:21 am
Hi Bruce
I will be going to Austechexpo next week.
For any others in Melbourne interested in going, here is their website with details and online registration.
http://www.austechexpo.com.au/
See you there Bruce.
regards
Lawrence
hajime
Post by hajime » Tue Apr 30, 2013 1:39 pm
Is it possible for you to show how M2 holes on a 1.5mm frame look like?
Lawrence
Post by Lawrence » Wed May 01, 2013 1:37 am
Hi
I have just printed this sample showing holes and curves, using genuine Up! filament with 0.15mm layers, and set to Fine.
The holes from left are 1mm, 1.5mm, 2mm, 2.5mm, 3mm.
Yes, there are small gaps in the print around the holes because I did not optimise the settings for the model, but these are only a distraction in this sample, and easily rectified.
1mm hole has a small dag that I didn't notice when the photo was taken but that can be easily removed.
The outer corners are 1mm radius curves.
First photo is straight off the printer. Sorry about my poor abilities at macro photography.
Set of holes 1.jpg (69.44 KiB) Viewed 12133 times
Second photo is with the raft removed but no other cleanup.
Set of holes.jpg (100.23 KiB) Viewed 12133 times
The images show the Up! capability at printing with small holes, so this is my last post on this topic.
Lawrence
Post by JuliaDee » Wed May 01, 2013 2:08 am
Lawrence wrote:Hi
Lawrence
Nice-looking parts, Lawrence! M2.8 nuts and bolt is impressive, too. I regularly make holes down to 1.3 - 1.5mm, no problem. Recently I've also been using the 4-layer option on many parts rather than the 3-layer - it's more drill-able and tap-able.
julia
josejuako
Post by josejuako » Thu May 02, 2013 5:20 am
:lol:
Post by roller » Thu May 02, 2013 10:09 am
[quote="josejuako"]Julia
The small hole diameter is 0.05 mm. and 1.8 mm. larger. . Whit the UP machine I do it .
Surely you mean 0.5mm?
josejuako
Post by josejuako » Thu May 02, 2013 10:55 am
:D
