Filament Regular , Colored and Clear
nz_andy
Re: Filament Regular , Colored and Clear
Post by nz_andy » Sun Dec 09, 2012 9:28 pm
I have been using the crystal clear, it is a robust material.
Actually I don't even think it is ABS, I think it is Polycarbonate, or a blend of both, it is totally different from the ABS, sweet smell if you burn it.
Bubbles up a lot as the extruder comes up to temperature, also a sign of PC as it absorbs more moisture.
http://store.3dprintingsystems.com/3D_P ... nt_Crystal
Post by wackojacko » Mon Dec 10, 2012 6:44 am
Print it on the fast setting for best results.
walter
Post by walter » Tue Dec 11, 2012 5:38 am
roller wrote:I'd love to hear feedback on the colour changing stuff.
I haven't used the Afinia color changing plastic, but I have a couple of color changing plastics (grey/white and blue-green/yellow-green) from repraper. Both print very well in the Up, very much like the octave and afinia plastics I've used. They grey/white turns into octave natural, the green/yellow one turns into octave fluorescent yellow. They do shift in color after printing, which is a shame since the starting colors are very nice.
Post by roller » Tue Dec 11, 2012 7:04 am
I thought they might. Most of those dyes are damaged by extreme heat and the Up does print very hot and relatively slow so they do get a good baking in the heat chamber. I wonder if printing on fast would help - I suspect it's not fast enough to limit the damage.
