Settings not enabled in Tiertime to change Nozzle Size
wendygilbert
Post by wendygilbert » Fri Nov 23, 2018 4:26 am
Hi Guys,
I have been having a problem with the Tiertime software in that I cant seem to get to the settings option, and if I click anywhere, I get the Printer Material is set incorrectly of the Nozzle size is incorrect.
The option is Greyed out. The only option available to me is the Print option,
Cheers
Wendy
TiertimeBrook
Re: Settings not enabled in Tiertime to change Nozzle Size
Post by TiertimeBrook » Wed Nov 28, 2018 6:27 am
Hi Wendy,
If you can change the nozzle diameter in setting ,Please confirm if the nozzle diameter matching the one you choosen in maintenance, and if it is a customized material, also check the material file if set well.
Brook
brooksjo
Post by brooksjo » Tue Jan 22, 2019 8:39 am
Hey there,
I'm having issues with the nozzle height and Data Transfer Failure occurs all the time. Is it possible to re-calibrate the nozzle height?
Tiertime contributor and 3D modelling reviewer via tamucc lab (section 3D technologies) and essay generator app.
