Printing a cylinder
moreupper
Printing a cylinder
Post by moreupper » Fri Nov 24, 2017 4:08 pm
I have a hollow cylinder outer diameter is 17 mm, and then a 10 mm thread inside.
When printing with studio latest version, it add support inside the cylinder but i set option NO SUPPORT! I cant remove it after print without the thread is damaged.
Why is it adding support when i say NO support?
Re: Printing a cylinder
Post by Owen Sparks aka Marksman » Fri Nov 24, 2017 9:50 pm
Because UpStudio :roll:
No supports translates to less supports, perhaps, if it feels like it.
brunningm
Post by brunningm » Sun Nov 26, 2017 8:57 pm
Tiertime don't think you can be trusted to make those decisions /s
So, I read somewhere that 'No Support' will still print 10 lines of support to help keep the print stable...not sure why they think that's neccessary but there ya go.
Also, go into the extra settings and make sure you've unticked 'Stable Support' as well. I found that leaving that ticked with no support would cause it to print support anyway.
rabiyajamal45
Post by rabiyajamal45 » Mon Mar 19, 2018 10:21 am
:roll:
