How to print without support
Nguyen Tam
Post by Nguyen Tam » Wed Jul 12, 2017 3:57 pm
I have the UP Plus 2 and am trying to print this fan duct, but it keeps filling in the duct interior with support, which becomes impossible to remove. I'm also running into the same issue when printing LEGO bricks. I can't figure out how to turn off the support. Any help? The documentation isn't really clear on this at all.
ricks01
Re: How to print without support
Post by ricks01 » Thu Jul 13, 2017 9:39 pm
in the print/preferences/support/ menu you need to select "ONLY BASE" in the area section
tel
Post by tel » Fri Jul 14, 2017 12:19 pm
Depends on the software version you are using. I think ricks01 solution relates to the old Up software 2.18. If using UpStudio in the print preferences there is a box you need to tick that says "No Support"
