Abs not sticking??? Help!!!
Fragmintz
Post by Fragmintz » Tue May 23, 2017 1:43 am
I have done everything, cleaned my bed, laid glue, set nozzle to 0.2mm , removed easy peel. And yet some.of my corners come.up after the 2nd later( after the initial pass). It gets to the first layer of the part and then I start to.see that it's popping off the bed
JuanCR
Re: Abs not sticking??? Help!!!
Post by JuanCR » Tue May 23, 2017 11:16 am
I should check:
1.- properly nozzle heigh
2- fan gate closed
3- the bed has reached the working temperature.
ricks01
Post by ricks01 » Tue May 23, 2017 7:37 pm
imprenta3d wrote:I should check:
2- fan gate closed
4- Bed not level
Post by DrewPetitclerc » Tue May 23, 2017 7:56 pm
Try a thin coat of Elmer's glue stick, the purple water washable kind on the build plate.
Robin
Post by Robin » Fri Jun 09, 2017 8:39 am
I had an awkward lifting corner that I accidentally fixed by switching the print to "fine".
I have no idea why this would make it stick, but stick it did.
Post by DrewPetitclerc » Fri Jun 09, 2017 10:49 pm
Robin wrote:I had an awkward lifting corner that I accidentally fixed by switching the print to "fine".
Slows the printhead down and allows a more pressed into build plate of the plastic.
