SD Card read error (SOLVED?)
Robin
Post by Robin » Mon Nov 21, 2016 10:00 am
SD card errors two days running...
I suspect the SD card holder is retaining liquid from the flux wash which is then evaporating to leave a waxy gunge inside.
A good squirt of Servisol Super 10 switch lube seems to have fixed mine. Has worked for a day, I will report back here if it goes again.
I went around the houses looking for the ROM data, found 3 of them dated 2012 in the UP program directory under /System but they wouldn't load.
