White ABS from UP in 700g reels gone!
Post by mr6k » Mon Nov 23, 2015 5:43 pm
In the UK I am having a hard time finding 700g reels of genuine UP ABS. All that seems to be available is 500g reels.
Has UP stopped making 700g reels for UP Plus etc
Re: White ABS from UP in 700g reels gone!
Post by mb20music » Mon Nov 23, 2015 8:29 pm
You can use Zortrax Z-ABS filament, it is the same as the OEM UP! and Afinia filament!
http://www.dream3d.co.uk/3d-printer-fil ... nts/#z-abs
steelmans
Post by steelmans » Tue Nov 24, 2015 11:52 am
mb20music wrote:You can use Zortrax Z-ABS filament, it is the same as the OEM UP! and Afinia filament!
Great bit of advice there. I assume it runs at 260 deg? Does it have the same support removal properties as the C-01 ABS?
steelmans
Post by steelmans » Tue Nov 24, 2015 11:54 am
mr6k wrote:In the UK I am having a hard time finding 700g reels of genuine UP ABS. All that seems to be available is 500g reels.
Peter, I have found a place where you can buy UP 700g C-01 ABS for £14 GBP. Not sure if it should be common knowledge so of you want to know PM me.
Tiertime-Jason
Post by Tiertime-Jason » Sat Nov 28, 2015 7:10 am
yes, 700g reel was gone. now only 500g reels available. I heard they are selling in 1 kg package with 2x500g reels.
Post by wackojacko » Sun Dec 20, 2015 4:22 am
There are now two types of Tiertime ABS 1) Original ABS in a matte colour and ABS+ a much stronger material but support removal can also be harder to remove.
