Filament to make rigid objects
Posted: Thu Mar 20, 2014 2:42 pm
by hajime
Hello, as of today, what is the best filament to use to make rigid objects such as brackets/frames on the Up Plus 2? Thanks.
Re: Filament to make rigid objects
Posted: Thu Mar 20, 2014 5:03 pm
by mr6k
I reckon ABS is the most rigid material with some bending strength. PLA maybe be a bit more rigid, however it is also brittle and biodegrades. Taulman nylon is strongest in terms of bending, but is a lot less rigid than both ABS & PLA.
Just my twopenceworth.
Posted: Thu Mar 20, 2014 11:24 pm
by hajime
mr6k wrote:I reckon ABS is the most rigid material with some bending strength. PLA maybe be a bit more rigid, however it is also brittle and biodegrades. Taulman nylon is strongest in terms of bending, but is a lot less rigid than both ABS & PLA.
Thanks. After reading the postings here, I thought nylon were the strongest. However, after I watched the videos of some products made of nylon, I realised that it is the stronglest in terms of not breaking easily when pulled from the sides. I am looking for strongest in terms of rigidity.
Posted: Fri Mar 21, 2014 12:02 am
by doraemon
Probably PLA is hardest. If you need it stiffer, you could always add gussets.
Posted: Fri Mar 21, 2014 2:43 am
by JuliaDee
Taulman 645 is more rigid than 618, and warps less, it's my favorite. T-Glase is also said to be very strong ("like printing with steel" someone said) but I haven't done too much with it. I have some Taulman "Bridge" on the way and will report after testing.
PLA is rigid but brittle, as others have stated. Support removal is a bitch.
Posted: Fri Mar 21, 2014 4:16 pm
by hajime
JuliaDee wrote:Taulman 645 is more rigid than 618, and warps less, it's my favorite. T-Glase is also said to be very strong ("like printing with steel" someone said) but I haven't done too much with it. I have some Taulman "Bridge" on the way and will report after testing.
Thanks. Please do let us know how it goes with Taulman 645.
I tried PLA on a Makerbot a year ago. I didn't like it. The stock ABS which comes with the Up Plus 2 seems to be better.
Posted: Fri Mar 21, 2014 4:33 pm
by JuliaDee
Taulman 645 is great, I use it a lot; it's Taulman "Bridge" that's new and which I will be testing soon. "The strength of 645 at the cost of ABS, with less moisture uptake and less warping" I think is the advertised feature set in a nutshell.
Posted: Thu Apr 17, 2014 4:57 pm
by hajime
Hi Julie, have you had a chance to test the 645?
Posted: Fri Jul 11, 2014 9:42 am
by hajime
Hello, any update in regard to the test results of 645 ?
Posted: Thu Jul 24, 2014 2:03 pm
by roller
It's worth checking out Polymakr polymax now too. An ABS strong and PLA stiff material - the best of both worlds.
Posted: Thu Jul 24, 2014 2:45 pm
by JuliaDee
More like "nylon-strong" - PolyMax is tough stuff (but not all that rigid, it's got some flex to it)
