Not all copies are equal
Ian Smith
Post by Ian Smith » Fri Feb 14, 2014 8:36 am
I wanted 2 copies of a component, so I loaded it once then I added an additional copy via the UP right click "insert copy" function.
It wasn't a very complex item, as you can see from the attached pic, just an end cap with a cavity for a cover strip.
I printed the item on its back, so there was almost no support material required.
One of the items ( pretty sure it was the copy, but can't be certain) was printed with the cover strip cavity half filled with what looked like raft structure i.e not solid just an open criss-cross of material.
A subsequent single re-print of the item turned out OK
Any clues please?
Thank you
Ian
end cap.JPG (41.06KiB)Viewed 4054 times
Lawrence
Re: Not all copies are equal
Post by Lawrence » Fri Feb 14, 2014 9:33 am
Hi
looking at the image, that could be the much wanted new Upsized Up!Mega
Lawrence
:lol:
